I successfully setup my 4 Arlo camera for Homekit this morning while at home. They appeared within the Homekit app just fine and I could pull up my live streams. Now that I am not at home, all of the Arlo cameras say "No Response". All of my other non-Arlo Homekit devices are working just fine. Also, if I open the Arlo app, all of the carmeras are online and working properly. However, the Arlo cameras don't seem to want to work within the Homekit app when I am away. Yes, I do have celluar turned on as well as Backround app refresh. Anyone else having this problem?
Just update arlo app this morning..their description state "Homekit related fixes"...so here i thought o they finally fixed the uncertified accessory error..went to try installing homekit and nope same error again. another fail by arlo.
Continuing to receive double alerts as well.
Do you have the Legacy app still installed or do you have more than one Arlo product that does geofencing. Both will cause double alerts. In one case it is a duplicate alert from the old app and in the other case it is a notification from each geofencing device on which Arlo unfortunately revoked our ability to control our own notifications consistent with our unique life situations.
I only have one Arlo system...the 4500R3 base and 4 Arlo Pro 2 cameras.
@DGArkie wrote:
I am running the new app and updated it to current this morning. The double alerts started when the replacement app was first installed.
If you are sure you have also deleted the Legacy version of the app, then you shouldn’t receive duplicate notifications For your configuration, of course. Do you have “In/Out” notifications turned on in ”Settings” for the Arlo app? That could duplicate notifications.
Is this possibly related to Home Kit? I don’t use Home Kit much at all. It is set up on my devices, but I don’t receive notifications from it.
I gave it one last shot deleted the base station and reloaded the cameras one by one and entered into homekit after entering into Arlo. It finally worked. I am running iPhone 10XS Max with iOS13.1 and 10 Arlo cameras and 1 OMNA camera. All seem to be working fine.
Do you mean that you had experienced the uncertified accessory adding station to HomeKit but finally success in last shot ?
@slimhavenNo that did not work. I just ran through it.
Several users are reporting problems with the HomeKit integration and this model of basestation.
In my case I’ve updated all there is to update and still I can’t even see the basestation in the “discover your device” setup screen, it just keeps searching.
Could it be that you could prioritize this issue with your development team so that those of us who paid lots of money for this product, could get what we pay for?
Best regards.
Has anyone actually solved the inaccessible accessory problem with Arlo and HomeKit. I tried for about a month, then gave up. My support request was escalated and confirmed in an email from CS, but no one ever responded and they don’t even reply to their own CS email requesting an update on the escalation. I assume Arlo CS simply can’t make it work, but I wondered if users figured out a fix.
Thanks. It’s probably time to sell the system on eBay and move on.
crazy its been this long and nothing has been corrected or addressed by arlo as being worked on. i gave up on trying to get homekit to work.
Arlo support called me the other day and told me to try factory reset the base station and try add it to homekit again, but they couldn't confirm it would fix it, was just something to try.
as i haven't really got time at the moment to climb up a ladder in three separate spots around the house to reset the cameras, i haven't tried it yet.
has anyone actually managed to get the system working in homekit after getting the "un-certified accessory" error?
I was told this too, it doesn’t work still.
Complete waste of time.
AppleTV
31 -
Samsung SmartThings
83 -
Security System
