- English
- Arlo Forum Discussions
- Partner Integrations
- Re: Arlo Pro 2 and Setting Up Apple HomeKit
Arlo just "upgraded" my 2 base stations with the sole purpose of being able to connect/compatible with Apple HomeKit. They sent me 2 VMB4000's Refurbished (no box, packaging or manual) When following directions to set up HomeKit under My Devices > Base Station... HomeKit does not appear. I have restarted reset and confirmed firmware on base sation as well as software on my AppleTV... nothing helps. I dont see any kind of Apple HokeKit code on the device itself and it didn't have any packaging so there is no way to scan a code that way. So frustrating and spent so much time on this... many many hours. It shouldnt be this difficult yet here I am. Please, any suggestions?
Thank you
VMB5000
Latest firmware 1.16.6.3_898_e9ee661
iPad OS app 3.5.6
Are you trying to use HomeKit with your VMB3500. This base station is not supported for use with HomeKit. You can find more info here: How do I connect my Arlo camera to Apple HomeKit?
I got Home kit setup with the other Arlo hub I think its the 4250 or something for Arlo Pro 3, however there seems to be no way to view iCloud storage, so I'm still storing locally to a Hard Drive.
I am still experiencing the issue, please help
I was told that the Pro2 hub does not support HomeKit.
Not sure what you mean by "Pro2 hub".
The VMB4000 and VMB4500 support HomeKit. The VMB3000 and VMB3500 do not.
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
