- English
- Arlo Forum Discussions
- Partner Integrations
- Re: Arlo Pro 2 and Setting Up Apple HomeKit
Arlo just "upgraded" my 2 base stations with the sole purpose of being able to connect/compatible with Apple HomeKit. They sent me 2 VMB4000's Refurbished (no box, packaging or manual) When following directions to set up HomeKit under My Devices > Base Station... HomeKit does not appear. I have restarted reset and confirmed firmware on base sation as well as software on my AppleTV... nothing helps. I dont see any kind of Apple HokeKit code on the device itself and it didn't have any packaging so there is no way to scan a code that way. So frustrating and spent so much time on this... many many hours. It shouldnt be this difficult yet here I am. Please, any suggestions?
Thank you
Thank you for the detailed info. You can try connecting to the 2.4 network on your device to see if that helps. if you still experience this issue, please contact the Support Team to further investigate the issue. You will find several options for contacting support in the provided link. Arlo Tech Support
can I get my token reset as well? having same issues with most here. on vmb5000na....
https://youtu.be/ypsM1LNdvqo
hi Shayne,
the reset did not work for me 😞
im on vmb5000na.
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
can reset the token again? im gonna give this one more try...
Sure thing, I just reset it again for you. If you want to try and leave the base unplugged for a few minutes that might help. You can also try & remove/Re-install the arlo app. Also, worst case, support might ask for you to factory reset to help with the HomeKit option populating within your app.
I followed the same process but I can’t pass this screen (as attached). Reboot doesn’t help. Firmware is latest
So glad I found this thread. Can my token be reset as well?
AppleTV
Samsung SmartThings
80 -
Security System
