- English
- Arlo Forum Discussions
- Partner Integrations
- Re: Arlo Pro 2 Not Connecting to Apple Homekit
The Model wouldn't go in because it wasn't in the dropdown list but I have the VMS4330P-100NAS.
Like many others I am having an issue with connecting my basestation to Homekit. I am assuming that I need the new Token from Arlo to reset the system. Also assuming this is something that I am unable to do myself? When I go the the connect to Homekit it just says that it is waiting to connect. If there are any other suggestions I am open to them.
Thank you.
I can reboot the base station, but still no good on the connecting to HomeKit.
Hi. I'm having the same issue. After spending 30 minutes with CHAT support going over all the same steps to add HomeKit I got disconnected and still have the same issue. My last question to support was, is the solution not as per this forum article that a token request is needed? https://community.arlo.com/t5/Partner-Integrations/How-to-add-HomeKit-after-removing-it/m-p/1774178. Is there anyway I can request this from the forum admin?
I can and I have. I have rebooted the basestation about a dozen times. This is not working. As I have read from other posts I likely need a new token sent to the basestation to get it reset for the homekit to work. Is this possible to have done?
Are you receiving the "uncertified accessory error"?
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
