- English
- Arlo Forum Discussions
- Partner Integrations
- Re: Arlo Baby not working with Amazon Echo 8
Our Arlo Baby camera worked for about a month with the Amazon Echo 8. But for the last two weeks it hasn’t worked at all. I have disabled/reconnected the device multiple times. I have disconnected/restarted the Baby camera but it hasn’t corrected the problem. It will say waiting for Arlo....then go back to the home screen after a few seconds. This is very frustrating since using the Arlo was the main reason we bought the Echo. Anyone have any ideas how to fix this???
6 REPLIES 6
Hi DKRandall,
Have you tried to disable and re-enable the Alexa Arlo skill to see if that helps?
Yes I have. It still does not work. I have also reset the camera itself. The longest the Echo will display the video is about 15 seconds before it goes back to the home screen.
I would suggest to contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
I’m having the exact same problem with the Echo Show 8 and the Arlo Baby camera. It started a few weeks ago.
I tried resetting the Echo to factory settings. It still only shows the camera for about 5 seconds before going back to the home screen. So frustrating!
Im having the same problem.
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
