- English
- Arlo Forum Discussions
- Partner Integrations
- Re: Issues streaming Arlo Baby to Google Home app ...
Just bought an Arlo Baby model:ABC1000, one of the main reasons was to integrate with my Google assistant.
Confirgured fine with the Arlo app, have this 2s delay with is acceptable for a wireless steaming camera, was able to integrate with Apple HomeKit, just to play and see how would work, everything is fine, even better audio quality (no tons of background/wite noise) and less delay, about 1s, then the arlo app. Big win for Apple software.
Now when if comes to Google environment, integrated ok but when casting to Google Hub or Chromecast on the TV have a 22s delay with the streaming witch is totaly unreliable for the use of this camera with Google assistant.
My wifi network is fine, not overloaded, AC router, 5hgz with band, good signal (not a big house) and worked fine with Arlo app and Apple homekit, this exclude the possibility of bad wifi set up. Have no problem streaming Netflix, music of other contant in my google assistant environment. Firmware is updated by the lastest release from Arlo app.
A 22s delay in a camera that supposed to help you take care of a baby is not a oppition.
Any sugestions on how can I make it work? or if it does work at all?
I have the exactly the same issues as stated above - what is the progress on a solution here?
How come there is no response yet?
Never buy Arlo again! Sucks!! This is the solution!!
I would argue that the best solution is to get a different camera. My Google Hubs aren't going anywhere.
Nest for sure, yes. I don't know which else. I replaced the Arlo with a Nest, and it works great. I also have Nest doorbell, so it's nice to have it all integrated within the Google Home app.
Wondering if there are any updates on this issue?
For anyone still experiencing this issue, please reach out to the Support Team to further investigate this issue or refer to this article: How do I connect my Arlo cameras to Google Home or Google Assistant. You will find several options for contacting support in the provided link.
AppleTV
33 -
Samsung SmartThings
88 -
Security System
