- 2
I rebooted again and do not have the HomeKit option.
Log out of the account and log back in, then reboot the basestation, after that then set up the Homekit without a code with the instructions I provided.
I followed your instructions and I still don’t have the HomeKit option
You will need to reset the basestation then, however please keep in mind that you will need to add all the cameras back onto the account.
That worked, thanks!
Unbelievable. iOS app updated to version 6.26.1 (25550) and HomeKit is gone again. Please reset my token
That has been reset.
Once I rebooted then went to settings, Device Info on the base, I happened to notice a quick flash so I took a video of me selecting Device info. The flash is the HomeKit option that then disappears. What could cause this? Should I factory reset again?
You will need to do the reset again and I will reset the token again as well. Lets try a reboot actually before doing a full reset.
After the reboot, same result
Okay then lets do the reset of the basestation.
- 2
AppleTV
33 -
Samsung SmartThings
89 -
Security System
