  • 35 Replies
  • 5990 Views
tfa225
I need a token reset please
35 REPLIES 35
tfa225
I rebooted again and do not have the HomeKit option.
BrookeN
Log out of the account and log back in, then reboot the basestation, after that then set up the Homekit without a code with the instructions I provided.
tfa225
I followed your instructions and I still don’t have the HomeKit option
BrookeN
You will need to reset the basestation then, however please keep in mind that you will need to add all the cameras back onto the account.
tfa225
That worked, thanks!
tfa225
Unbelievable. iOS app updated to version 6.26.1 (25550) and HomeKit is gone again. Please reset my token
BrookeN
That has been reset.
tfa225
Once I rebooted then went to settings, Device Info on the base, I happened to notice a quick flash so I took a video of me selecting Device info. The flash is the HomeKit option that then disappears. What could cause this? Should I factory reset again?
BrookeN
You will need to do the reset again and I will reset the token again as well. Lets try a reboot actually before doing a full reset.
tfa225
After the reboot, same result
BrookeN
Okay then lets do the reset of the basestation.
