bryantrichar
I've seen some responses about needing a token sent for this issue?
160 REPLIES 160
BrookeN
You are on the old user interface and have not migrated yet that is why you are unable to see it.
Buskins
CT2023
Hello,
I have added a second Apple TV, in another TV, with the same username. I can see the Arlo cameras but they all show only "no response". I tried reseting the new apple tv like 4 time, readded the user but still the same "no response" message.
Please help
Regards
CT
1westside1
Can I get a reset token as well?
BrookeN
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:How do I connect my Arlo device to Apple HomeKit?
Kyle7676
Can you please send a token refresh. Thank you
BrookeN
Sp00kySpic3
@BrookeN
Can I also get a token reset?
Thank you!!!
BrookeN
Tanraell
Can I get a token reset as well please?  My hub suddenly stopped working on HomeKit and I can’t add it back.  Thanks!
BrookeN
ndro777
Hi, can you also please send a token to my device? Having the same issue.
Thanks in advance!
BrookeN
@ndro777 is your devices connected to a hub or basestation? Looking into resetting the token I do not see a basestation/hub on the account.
ndro777
It is a base station. I can give you the serial number if that helps?
BrookeN
Can you private message me the serial number as well as the email address it is attached to?
ndro777
Will do!
BrookeN
Messaged you.
Pasipeikko
I have the same HomeKit problem as others. Cannot add Smarthub. Can i get a token also?
BrookeN
BBence
Hi! I have the same problem, can you send me a token reset?
BrookeN
RobvH
I also need a token reset for the base station (ultra smart hub and ultra2 cameras).
Rob vH
BrookeN
BBence
Hi! Can you please reset the token for me again, the same issue just happened?
Regards
BrookeN
