Can I get an token reset for the two SmartHubs associated with this accounts email address?
Hi JamesC
Can I also get my Arlo Pro token reset please. I thought I had a bad router cause it was working before on my Netgear x6 router then it stop working so I threw that router away and bought myself an ASUS router only to find that I still get that Discovering Device waiting issue when adding it to HomeKit. Please advise what info you need from my Arlo. Also, once token is reset, what do I need to do on my Arlo. Just restart it? This should be a simple as adding the HomeKit again but somehow that Discovering device thing always comes up and nothing happens….Please help, thanks!
Hello may I also have a token reset for my base station please.
Thank you!
Sir_rey, DazzaB
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
Thank you worked perfectly
Thanks James it worked perfectly and I have all three BS in Homekit now.
Thanks again
That work! Thanks JamesC. Darn it though, i must have thrown a perfectly working router away LOL. Oh well....no matter, just glad i got to add it back again. Thanks again!!
Mattm1,
4RC38172A178B
Hello, Can i have a token reset please?
Same here, please send a token reset … thx
Leonardomax2, RHead
VMB4000r3
Hello, Can i have a token reset please? Thanks
TheKFCuracao,
Chris_Astro,
James, please send a token reset for my base again. It stopped working as discoverable in Homekit again
Thank you
Hello
Requesting to have my token reset pleasee!!!! I had to reset my router to manufacturer default settings and I lost the HomeKit intergration on my Arlo Pro. Let me know.
Sir_rey
I'd like to request a reset token sent as well to my basestation.
Still waiting for a token reset
Jamco, Sir_rey, micasa-elysian
Can I please get a token reset for my base station? Thanks!
Quickgrits,
can t use homekit. it keeps rotating. can an homekit token fix it? And how do I get this if this is the solution. Greetings Fred.
fre3co,
Hello
Requesting to reset my Arlo token please. Homekit was working then it stop so i tried adding it again via the Arlo app but if just keeps saying Devices found but status keeps circling.
thank you
Sir_rey
AppleTV
33 -
Samsung SmartThings
89 -
Security System
Verisure
