  • 14 Replies
  • 6941 Views
  • 2 Likes
  • 7 In Conversation
DJD
Ever since the firmware update my Netgear base station has not updated and the mode function on my mobile app no longer works. I have been in lengthy correspondence with the support team who either do not read my previous messages properly or are incompetent. I have tried everything they have suggested several times but to no avail. They ignore my request to replace the base station which I have concluded must be faulty yet still under guarantee. For anyone reading this I suggest you buy an alternative system from a different vendor.
14 REPLIES 14
DJD,
Please send me your case number in a private message for further review. I would be happy to take a look to and see if I can't assist you further with this issue.
Does the mode function work on the web client or is this issue exclusive to the mobile app?
Kwitzzy78
I, too have the same problem with the App and also the web client. I'm no longer able to delete clips in my library either. Please help
Kwitzzy78,
Consider a reboot (on/off button on the back) of the base station. Please let me know if you continue experiencing this issue after the reboot.
johnbmwm6
I only bought this today, it does not work, no Mode shows in the Mobile phone re-booted still nothing, it goes back tomorrow.
EDIT: Re-booted again now ALL WORKING!! great now we can get going.
demetreb
There has yet to be any real solution to it. I too have been in lengthy corespondence with tech to no avail. Reset reset reset and Uninstall re install us their only solution. We just have to get used to signing in and out 4-5 x to check our system on our phones.....
Since your situation seems to be unique, it would appear to be something in your setup or devices. What OS are you using? Are there different devices and OSes?
johnbmwm6
Hi I solved it by reloading the App on the Phone twice, them the Menu came up and it's worked ever since.
So Happy.Man Happy
demetreb
Android. Up to date. I've been through it several times with the tech support. They are as lost as I am. There are a few other posts on the subject so not is not as unique as assumed.
demetreb,
Is this an intermittent issue or does it always occur when trying to access modes from your mobile device?
demetreb
JamesC. This is a consistent issue. If I go another screen or section on the app and return to the MODES screen it is blank.
demetreb,
Please provide me with your support case number (in a private message). I would like to further investigate this issue.
Thank you,
4metoo
If you get any help please post as I have a 2 week running case with Netgear support on the same issue with no sign of any resolution.
johnbmwm6
Hi I have the HTC M9 android, my app did not work at first, I deleted it re-downloaded it and it worked very well and still does.
No problems with it now at all.
demetreb
Always. If I access the Mode section first I can access all the modes and schedules etc, however leaving the mode section and going to cameras or the library sections viewing a vid or viewing a camera THEN back to the Mode section ... it is blank....i can still access the camera and library sections but not mode....log out and in again to access modes
