  • 5 Replies
  • 6334 Views
roby1er
i bought my arlo pro in december 2016
I create my account and add a guest. I use app arlo with android.
no problem.
Today, I add a new guest,
Problem with the appz android, the guest have access  to the alarm but don t have access to  the mode.
we can launch the alarm sound but we can not see the mode, nothing in the mode menu blank.
I try the appz in iphone and ipad everything works perfectly.
so could you fix the problem.
app android 2.3.2_16308
5 REPLIES 5
Did you granted the new user the additional privileges in Grant Access?
roby1er
Yes of course.
Everything Works perfectly with the app for iPhone. but not with Android app. When i go to the mode menu  I see nothing. Blank page.
same result with  two android mobile.
With the iPhone. I can see the Arlo icon and then l can activate or not the alarm...
Thanks for your help.
Reinstall the Android app and restart the phone. Might be that simple.
roby1er
Tanks for your help.
But it s already done in Both mobile Android. ZTE and Samsung note 3.
Before opening a case with support, all I can think of is to go back to Grant Access using the master account and toggle settings, save and then back agai, saving again.  If that has no effect, then a case is likely needed.
