- 2
A request was posted in Ideas that they would rather receive TEXT messgs instead of emails ( as it's easier to view at times ).
I just wanted to repost the answer as user tip;
If you want to get text messgs instead of emails, use the format to convert an email to sms ( text ). I also use this on a dumb non-smart phone when needed ( yes there still are some out there 🙂 ).
for exp; in verizon if you use phone#@vtext.com for your email, the messg will show up in your phone as an sms messg.
check with your phone service for the proper format to do this
formats as follow;
AT&T: cellnumber@txt.att.net
Cingular: cellnumber@cingularme.com
Metro PCS: cellnumber@MyMetroPcs.com
Nextel: cellnumber@messaging.nextel.com
Powertel: cellnumber@ptel.net
Sprint: cellnumber@messaging.sprintpcs.com
SunCom: cellnumber@tms.suncom.com
T-Mobile: cellnumber@tmomail.net
US Cellular: cellnumber@email.uscc.net
Verizon: cellnumber@vtext.com
Virgin Mobile: cellnumber@vmobl.com
Alltel: cellnumber@message.alltel.com
Sprint: cellnumber@messaging.sprintpcs.com|
What are you trying to achieve with a NSX number of XXXX ?
Hi does anyone know the way to convert email to text with Three in the UK, please.
i have tried number@three.co.uk and number@three.com. I have tried number without 44 and with 44 (minus 0).
Twosmiles,
A quick google search on the topic came back with number@smtp-mbb.three.co.uk. Worth a shot. Let us know if this works for you.
Hi, I am an Australian user. I just completed the newest app update and now I'm uddenyl unable to receive Text notifcations, whih I've been receiving all along. Anyone help with turning these text messages on (the phone pathways above are for the US, and arent; applicable for Australia).
Many thanks for any help.
Many questions and answers on this. Have you checked your modes to turn notifications on?
After the update, I had to reconfigure the camera rules to send email alerts and text messages. For some reason, the update retained my email address but stripped the address associated with the text messages. Once I did that the email and text message alerts worked fine.
I spoke a little too soon. The email and text notifications had been working fine, but a test about 20 minutes ago indicates otherwise. Neither of them have shown up, nor has the recording shown up in my library. I am generally aware of similar reports, and of some acknowledgement of technical difficulties being worked on. Maybe that's it.
mep123,
Are you still having issues receiving notifications/recordings? Please let me know!
Hi James,
Yes, still no texts. Getting 'notifications' and emails, but no text messages.
Thanks,
Thanks for your response, sounds promising that they're working on it, maybe in the next update? Still no text option for me though (but can get notifications and emails).
Cento,
Arlo does not send text notifications only push and e-mail notifications.
Hi james,
Yes, i got confused - I meant ntofications. I was not getting notifications (the little red ones or twos that come up on the app), but I received my iphone update, and am now getting them but without sound? I haven;t really fiddled with this problem yet, so I'll see if there's any settings I need to chage.
many thanks
JamesC wrote:mep123,
No. App, email, and text alerts are all working fine now. Thanks for asking.
Recordings are also showing up right away in my library.
Thanks so much for your follow up
Cento,
Glad to hear the issue is resolved!
I am not able to configure text alerts on T-Mobile using cellNumber@tmomail.net as suggested in one of the reply on furum.
I also spoke to tbobile customer care and got no help. They said nothing is blocked at their end.
Has anybody done it and provide some input.
Thanaks
Thanaks
don't know if yours is, but it may not work on a pre-paid phone.
As a PS... to check if it's a problem from the domain name... try and use a few diff emails servers (gmail,hotmail.etc ) and test to see if you get them
- 2
