Hope y'all get your Arlo up and running soon. I'm just curious..I do not subscribe to the Arlo cloud service since I only have 4 cameras. Do y'all subscribe? Wondering if that could be part of the issue?
Some folks have started adding a new camera that doesn't actually exist. This causes the base to check for updates and has installed it. After that has finished, simply cancel the new camera install.
Nope, has nothing to do with the issue.
Thankfully all 5 cameras are back up and functioning properly again like before the new base station firmware update 1.12.2.0_2794 on 4-19-19. The older base station firmware 1.12.0.1_27940 has been restored in its place as it seems many Arlo users have experienced. I can now monitor my house as needed until they figure out what the problem with the newer firmware update is.
Base station model VMB4000
Interesting that the Arlo system came back online this morning. It would be nice if this company could have let everyone know that the system was down. I certainly hope no one got into a trouble situation with the failure of a company that had no communication with its customers.
I'm back online this morning. Netgear must have resolved it last night and updated everything.
Thank you jguerdat. I tried that but it still would not update. So I found another thread on previous update issues. Someone tried cycling router on and off and then the base station. That worked for me.
Arlo is aware of this and working on it.
If the problem is on their end why don’t they get on the board and let everyone know what the issue is and when we can expect a fix? I’ve had mine 6 days now and they are back offline for the third time. I’m at work and can’t reboot. Kind of defeats the purpose if they only work when I’m home.
Mine died this morning, probably after getting the old firmware. Hopefully a reboot when I get home will work. Maybe Arlo should test their firmware before making us upgrade.
Hey all, I had the same problem. on Thursday 18th I had a message that I "had" to update the firmware on my arlo to use it. So I updated it via the android app using my local wireless connection (same network). Waited, and waited some more. Eventually got message that base station was offline, go to support.arlo.com.
I left it alone all weekend without touching it at all. Today, still in same situation. So I powered it off completely and back on. After 10 minutes same problem.
Now pressed and held reset button on base station for 10 seconds. Still shows offline.
Go through wizard to add a base station. It finds one!
So I go back to main screen and remove my existing cameras and base station. Done.
Now going through wizard to add base station. Finds it immediately!
Displays message about checking for firmware update. Stays on this screen for 2 mins.
Seems to have been successful.
Now adding camera, had to remove batteries to get the blue flashing LED.
Camera added successfully.
System seems to be working fully now, although my camera batteries are basically drained at 1%.. uffff
Hope this helps someone else too.
Looks like it might be fixed. The live view of the cameras is now working and it is not prompting me to update the firmware anymore...
Ok, it's reverted to the old firmware as of this morning and seems to be working again.
The engineering team is investigating the cause of these issues. For those of you who experienced issues with the previous firmware version, we'd like to know the following:
-Your internet service provider (Verizon, AT&T U-verse, Cox Cable, etc.)
-Details about your network setup (Firewalls, non-standard router configurations, etc.)
-Router/Modem make and model (NETGEAR Nighthawk R7000, etc.)
More details the better! Please let us know.
Thank you,
I gave all kinds of information including this to the rep I had a chat with last night. Mines working again now that they rolled the firmware back.
Shaw Internet
No firewall, no mac filtering, standard setup
Base HW VersionVMB4000r3
As I mentioned I am away from the premises and couldn’t do anything onsite to the base station - so the update appears to have eventually happened remotely !
Cox and a Netgear N300 router
Whoa!! Wait a minute @JamesC. Why give our home network details over unsecured means??!! All the information you're asking for can be used by someone nefarious to gain access to our home networks. I don't understand why Netgear would want this infromation for a firmware or hardware issue - irrelavent! A user can troubleshoot without divulging sensitive information about their network.
Yep, getting same message since last update. Phone constantly shows "getting status" however everything is okay on desktop. Can't carry the desktop around with me. Not happy with this last update.
For about 2 of the past 6 months my cameras have beeen down, the orignal Arlo system. I have 5 originals and I am constantly replacing bateries and about once a month I get a message:
