On Friday 4/19/19 we released firmware for base station models – VMB4000, VMB3500 and VMB3000. Some customers have reported seeing error messages when live streaming and issues receiving motion recordings. Due to these reports, we are rolling back this release to the previous firmware version (1.12.0.1_27940) while we investigate these issues.
If you begin experiencing one or more of these symptoms, please power cycle your base station and confirm that your firmware has reverted to v1.12.0.1_27940 – found under Device settings. To power cycle, choose the ‘restart’ option under your Device settings within the Arlo app or by unplugging and re-plugging power to your base station.
We apologize for any inconvenience caused. Please let us know if you are still experiencing these issues.
Thank you,
Arlo Team
Arlo app will not load live feed of cameras. I can view the library clips just fine, but when I switch to devices so I can see what it is currently looking at it just spins and spins. I have restarted my phone, hit the sync button on the base station, and logged out and into my account. Nothing is working.
Thanks in advance for any help!
I can’t get mine to live feed either. It’s also not very sensitive to motion. On 100% I have to jump up and down in front of the camera to make it detect any motion. So far I’m less than impressed.
me too, they could not help me. must be their screw up
Have you rebooted the base? Are all firmware up to date as well as the app? Have you tried a computer browser?
When setting the sensitivity, are you doing so in your modes and rules? The motion detection test doesn't save anything - it's a test. Read the FAQs here on setting sensitivity as well as best camera positioning.
I continue to get problem establishing a connection to media server. Have reset router and re-synced but still receive message. This started this morning. Help! None of my cameras work.
I'm having the same exact problem starting today. I'm assuming the issue is on Arlo's end with this many of us suddenly experiencing the issue.
I’ve rebooted 3 times, completely deleted and started from scratch twice, and rebooted the router twice. I did finally get it to go live and if you get right in front of a camera and jump up and down it will on occasion detect motion. Not quite what I expected. All firmware for base and cameras are up to date.
Ditto. They quit sometime after 3:00 AM on 4/19 EST. Incredibly frustrated. I've been using these cameras for the better part of a year to successfully alert when my elderly father-in-law gets up in the night. NetGear should respond...
(IPad & iPhone App) No live stream, no alerts, no recordings. Basically, the system has internet, the base station is connected, cameras are connected and library files are accessible/ viewable. Everything has been rebooted, including modem & router, batteries removed, cameras synced and eventually Arlo “reset” returned to default settings. Still having same issue. Next, I went to my PC for live stream and it promptly said “Having issue establishing media server”. So, I am convinced that this entire issue has something to do with Arlo...the cameras will not view, therfore no alerts, no new videos and no live stream.
* FYI- If anyone is having issues getting your base station back on line, you will have to remove the base station and then add it back in order to get it back on-line. Go to settings- My device- Remove base station.
Additional info...
I've reset the base station and re-added the cameras. Neither live video nor motion detection works. Live video does not work on iPhone and it doesn't work on either Chrome or Firefox browsers from a Mac.
The message I get when trying to view the camera feed(s) from a browser on the Mac is always the same... "There was a problem establishing a connection to the media server."
On the iPhone, there is no error message - simply the spinning activity icon...
Use the Restart selection in Settings, My Devices, your base, if available. Use the power switch on the base. Unplug it and plug it back in.
Not working for the Arlo Pro's as well...
I escalted this and nothing from them.. They said "engineering is reviewing"...
It has been 24 hours and some customer ARLO are not recording any motion! LIVE view does not work. I am about to throw these Arlo's in the trash and get a Ring or a Blink system. This is complete downtime for us having this issue...
Count me in too! Still get motion detection alerts on my phone but no recordings and unable to connect to live stream. Have restarted etc etc etc ... but not go.
My camera dropped offline for no apparent reason after working fine for well over a year. I recharged the batteries and it powers on but it will not sync to the base. I have rebooted my ISP Router, the base, removed the camera as a last resort and now the base will not recognize it at all. When I attempt to sync it the blue light just flashes slowly. I did see other posts with the same issue but no definitive resolution other than replacement.
When I try to email support the link loads and then mysteriously vanishes as I'm typing??? Arlo support is a joke!
Any ideas on fixing the camera or contacting support?
I noticed today that all my Arlo pro 2 cameras stopped working last night. When I access the arlo app all the cameras show the last motion detected (which is 24hrs a go now) and the cameras don’t show as offline.
I now can’t access the cameras in live mode and no cameras are detecting motion. Have tried removing camera and resyncing and also rebooting home base and neither of these have helped.
Any ideas?
Make sure you are doing a Quick press on the base sync and then the camera button...( don't hold )
( also, you can do it without using the app/prgm )
Same issue here. Been going on for the past 24 hours.
I'm having the same problem, I've re-syched twice and rebooted the modem, but still won't establish a connection
