I'm having the same issue. Lost all video and recording since 4/19/19.
Here is what I tried unsuccessfully:
Powered down the router and base station - no result
Reset the router and base station - no result
Removed batteries from all cameras
Reset base station to factory default
Removed all cameras and base station from app
Reinstalled all cameras and base station according to directions
This time the cameras appear in the device menu but I can't see any live video and it's not recording
I can see a picture of the new camera position/view by navigating:
Camera 1 - Settings - Video Settings
When I go back to the device menu and click the cameras for a live view - nothing
No results on the iphone - "The data failed to connect. Please try again"
No results on website - "There was a problem connecting to the media server"
Im so frustrated - I've spent hours on this and tried tech support but with 19 people ahead of me, decided I couldn't spend anymore time. Might downgrade my package back to free and sell these cameras for something reliable.
Please let me know if you hear anything...
Hi, I'm as of 2 days ago I my cameras won't connect. They are synced with the base station and all I get is the "connecting" status on my app, but they won't connect. When I go on the Arlo site to view cameras I get the message "there was a problem establishing a connection to the media server". I have tried everything except resetting to factory defaults to get my system back online. Does anyone have any idea what's going on reference to this issue? I have had the system for about 3 months and it worked perfectly until just 2 days ago.
I am seeing the same issue and have for the last 24 hours. Neither of my camera types (Gen 1 regular and Gen 1 Pro) will record or show a live feed. It is not connectivity out of my network and I checked multiple DNS servers for arlo.netagear.com and the results are the same. I already rebooted everything and the kitchen sink with no resolution.
LamX
Very frustrating I know....
I had the same problem with my Pro 2. I couldn't even reboot its base station remotely! I had to physically press its power button off and on to power cycle it. It works now. Sheesh! Weird that a power cycle didn't work for you. Did you also try unplugging and replugging its power cable?
@JustJeff2 wrote:
I called tech support and after unplugging the base unit for a full 10 seconds (I did not disconnect the network cable) and plugging back in again all systems were go. Mind you I had restarted 3 times remotely and even unplugged once before. It’s been working since though.
Are you sure the reboot happened remotely? I noticed my Pro 2's base station's lights were not even doing their boot ups. It never rebooted when I tried twice. I had to physically press its rear power button to reboot and fix it. 😞
Cameras still down I have tried everything!😣
I've tried all of these re-set options but there is still "no connection to the media server". Tech support, are you listening???
Hi
Base has 3 green lights.
Tried the browser, as with the app I can see all cameras but when i try to watch live i get the error:
The cameras have also not been detecting sound or movement for the last 24 hrs
I have not heard anything my cameras have been off all day. I have tried everything still not working.
I have the exact same issue. My Arlo cameras have not been working for the last two days (Friday 4/19 and Saturday 4/2019) . I can connect to the base station remotley, I just can't view the cameras and motion recordings are not happening.
I have ruled out connectivity (packet captures, firewall logs, signal strength, are all good).
I opened a case with Arlo chat support Friday and nothing has ben done.
I came to rely on these cameras as part of my homes security posture and was considering upgrading to the latest version and after this experience I most definatly won't.
I can accept a service interupption of a few hours but were up to 48 hours now.
Arlo was attractive because it did not require a subscription like Nest, but after this experience I can't rely on Arlo.
I am under the impression Arlo runs a lot of it's infrastrucutre out of AWS. With cloud technology where its at this doesn't cut it.
This seems to be an issue on Arlo's end. My cameras have been having the same problem for the last two days. Arlo will not provide a estimated time of service restoration.
I am experiencing the same issue and have been for the last 48 hours.
This is a problem on Arlo's end and Arlo support is unable to provide me with a estmated time of restoration.
thanks for your reply.
this is very dissapointing and concerning that this issue stops the whole system from working.
lets hope they fix is soon.,
This is most likely due to a wide spread outage that Arlo is currently experiencing. My cameras have not been functioning for the last 48 hours. The fault is on Arlo's end, not my system or network.
