  • 10 Replies
  • 3310 Views
  • 8 In Conversation
tbaptist
After latest Arlo iOS app update (3.5.4) every time when checking the library the app pushes it to the past day & not current videos. I've tried restarting the system & even deleting and re installing the app but it continues.
ShayneS
This issue should now be resolved with the latest Arlo Mobile app v3.5.6. If you do not see the update in the App Store, please try removing & re-installing the Arlo app, you should have the latest version after the reinstall.
Best answers
  • ShayneS
10 REPLIES 10
dcfox1
Just tried  it here and yes it does go to the previous day. Iphone 8 plus.
ShayneS
Thank you for the report. I will look in to this and provide an update as soon as possible.
ShayneS
TacoIsLife
Every time I open the Arlo app, then going to the Library, it prompts to the day before instead of the current day. Are you guys having that issue as well?
Dannybear
Just a heads up to those getting similar quirky behaviour using the latest arlo iOS App.
When selecting the library page the day selection immediately reverts to the previous day. This seems to be dependent on the time of day as if the selection time is behind by 12hrs.
When opening the app the loading symbol is constantly spinning while on the devices page. This seems to be intermittent on login as if one of the arlo servers are not updated correctly.
App reinstall and phone reboots seems to be ineffective.
pipe51
My I phone will not show the clip that I pick from the library  . It shows one recorded later in the library. From my wired video door bell.
DanielleN76
I'm having the same issue when I go to my library. It's always on the previous day. Any fix to this problem?
tbaptist
With the new app update this is still happening. The library returns to the previous day.
jacobm91
I've been having the same issues for over a month now. Glad someone else brought it to their attention because it's been annoying.
ShayneS
