After latest Arlo iOS app update (3.5.4) every time when checking the library the app pushes it to the past day & not current videos. I've tried restarting the system & even deleting and re installing the app but it continues.
This issue should now be resolved with the latest Arlo Mobile app v3.5.6. If you do not see the update in the App Store, please try removing & re-installing the Arlo app, you should have the latest version after the reinstall.
Just tried it here and yes it does go to the previous day. Iphone 8 plus.
Thank you for the report. I will look in to this and provide an update as soon as possible.
When selecting the library page the day selection immediately reverts to the previous day. This seems to be dependent on the time of day as if the selection time is behind by 12hrs.
When opening the app the loading symbol is constantly spinning while on the devices page. This seems to be intermittent on login as if one of the arlo servers are not updated correctly.
App reinstall and phone reboots seems to be ineffective.
My I phone will not show the clip that I pick from the library . It shows one recorded later in the library. From my wired video door bell.
I'm having the same issue when I go to my library. It's always on the previous day. Any fix to this problem?
I've been having the same issues for over a month now. Glad someone else brought it to their attention because it's been annoying.
