What batteries and type are you using?
If you buy cheap crappy batteries, that's one explanation. If you use good batteries and insert 4 new batteries and the battery level is around the 50% mark, that's failure to make a good contact somewhere.
Post a screenshot of your app
It’s best and much cheaper to use recharable batteries. Batteries Direct or any reputable business sells them reasonable. I’ve got 5 cameras and 6 sets of 4, it works great.
Also, the batteries that came with the cameras worked great for a few months.
IMHO, it’s cheap or fake labeled batteries.
GL
so deleting the device and re-adding it fixed the problem.
I use cheap batteries and have used cheap batteries since purchasing over a year ago. The batteries are changed about every 6 weeks,
