  • 5 Replies
  • 2773 Views
  • 5 In Conversation
missgussy
5 REPLIES 5
ArloFYourself
I have the same issue. I think the camera is bad. This isn’t a very good system
What batteries and type are you using?
steve_t
Master Master
If you buy cheap crappy batteries, that's one explanation. If you use good batteries and insert 4 new batteries and the battery level is around the 50% mark, that's failure to make a good contact somewhere.
Post a screenshot of your app
Dholliy
It’s best and much cheaper to use recharable batteries. Batteries Direct or any reputable business sells them reasonable. I’ve got 5 cameras and 6 sets of 4, it works great.
Also, the batteries that came with the cameras worked great for a few months.
IMHO, it’s cheap or fake labeled batteries.
GL
ArloFYourself
so deleting the device and re-adding it fixed the problem.
I use cheap batteries and have used cheap batteries since purchasing over a year ago. The batteries are changed about every 6 weeks,
