Can you just replace the batteries, or do you have to resync the camera (or all the cameras) after replacing batteries?
Just replace 'em.
Just replace 'em.
Thank you, will do my first battery replacement today.
Open the battery door, install new batteries ( watch polarity )
You can attempt first with one camera... Go to settings and REMOVE DEVICE for that camera... then bring back as new. ( don't forget its a QUICK push on the base sync button, don't hold )
If it doesn't work, let us know
I even bought a new camera and it wouldn't synch.
I have 2 base stations and 14 cameras but 4 won't synch.
Last software update caused problems and battery level indicators don't work at all. They go from full bars to camera offline with no warning.
I am getting super frustrated after investing $1500 in this system and lack of a 800 number for support doesn't help the situation.
Paulch,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link. If you have any additional questions/concerns feel free to private message me. I would be happy to help.
