Web portal video-calendar providing invalid information
  • 16 Replies
  • 5694 Views
Retired_Member
Not applicable
Issue:  I click on the videos for Camera 1.  The calendar shows a dot under today's date which is good because I have videos there.  The calendar also shows dots under the 5 days prior to today.  I do not have videos for this camera on those dates, but I do have videos on those dates for other cameras.  The calendar filtered by individual cameras is idicating available videos in the entire library instead of the individual selected camera.
This is a change in behavior.  It used to work properly in the web app.  It still works properly in the iOS app.
ShayneS
Hi @Retired_Member
There has been an update that was supposed to address this issue. Are you still experiencing this issue with your web filter (Calendar dot)?
16 REPLIES 16
Try a reboot of the base via the power button  ( off then on, let reset )
Retired_Member
Not applicable
@TomMac
Thanks for the suggestion.  I did try that before, but just tried it again now just in case.  Nope.  The calendar still shows a dot where there are videos for other cameras and not the one I'm currently viewing.  This is an issue with the web portal design.
@JamesC , I've also been seeing this for a while (and I agree with @Retired_Member that it is a change in behavior).  I can't confirm that it is connected it to other cameras making recordings (I don't think I've ever had a day when there were no recordings from any camera).
For instance, this particular camera hasn't made a recording since 5 December:
Retired_Member
Not applicable
@StephenB @TomMac
Yes, this is exactly the issue.  I can confirm that if there are no videos in the library from any camera in the system for a particular day, that day won't have a dot.  (i.e. 12/6)
Retired_Member
Not applicable
Still waiting for a fix Arlo
ShayneS
Have you tried contacting customer support regarding this issue? I have attached the link here for you - Arlo Tech Support
Retired_Member
Not applicable
This is still broken.  Can we get some kind of response that it's a known bug and is being worked on?  Or tell us that you think it's another brilliant design feature, or something.  Some official recognition of this bug would be appreciated.
ShayneS
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
Retired_Member
Not applicable
@ShayneS
As has been confirmed in this thread, it's not an end-user issue, it's a design issue.
Retired_Member
Not applicable
Please fix this.
Retired_Member
Not applicable
PLEASE FIX THIS
ShayneS
HI @Retired_Member
Thank you for the detailed information, I have reported this to my development team. I will provide an update as soon as possible
ShayneS
Retired_Member
Not applicable
FIX THIS!
ShayneS
Hi @Retired_Member
Retired_Member
Not applicable
@ShayneS
Yes!  It does appear to now be fixed!  Thank you developers.
One down, several more really bad design flaws to go...
thanks!
