I have a WiFi connection, NTGR_VMB_ (+10 digits) , auto-connecting to my laptop - what is it?
It AUTO CONNECTS - and I have my available wireless connections requiring a "manual" connect. This wireless connection "CONNECTS" automatically, I disconnect it by the selection box, and it reconnects.
What is it and how can I find out more about it?
Is there Arlo software I can use to identify the product and it's application(s)?
How do I keep it from connecting to my wireless?
Thank you -
This is a windows question actually.
If you are using Windows 10, then try the procedure here: https://kb.netgear.com/29889/How-to-delete-a-wireless-network-profile-in-Windows-10
Do you own an Arlo base station (likely labeled "Netgear" in this case)?
