  • 4 Replies
  • 2103 Views
vnguyen251
VMB3500r4 base station with camera are slow.  Video feed has 5-10 seconds delay.  All cameras are less than 50 feet from base station and signals are quite strong.  It is useless to have security camera that has 5-10 seconds delay.  It is trash.
JessicaP
Hi vnguyen251,
Have you tried rebooting your Base Station to see if that helps with any delays that you're having?
vnguyen251
I rebooted the base station but it did not help.  I think it's just a crappy system and cameras that NetGear sent me.  I will just chuck the whole thing in the garbage and buy a few more of Nest cameras since I already have Nest doorbell.
JessicaP
I would suggest to contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
vnguyen251
I would love to contact support.  Unfortunately, the entire system I have is crappy so there is no amount of support will fix this.  I will go with Nest camera.
