VMB3500r4 base station with camera are slow. Video feed has 5-10 seconds delay. All cameras are less than 50 feet from base station and signals are quite strong. It is useless to have security camera that has 5-10 seconds delay. It is trash.
Hi vnguyen251,
Have you tried rebooting your Base Station to see if that helps with any delays that you're having?
I rebooted the base station but it did not help. I think it's just a crappy system and cameras that NetGear sent me. I will just chuck the whole thing in the garbage and buy a few more of Nest cameras since I already have Nest doorbell.
I would suggest to contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
I would love to contact support. Unfortunately, the entire system I have is crappy so there is no amount of support will fix this. I will go with Nest camera.
