VBM 3000 Basis Base Station Not Discovered
Refurbished unit - just connected for first time to (Netgear) router and green led for Power and Internet on
Using laptop Windows 10 - connected to cable broadband and WIFI working
All other WIFI and bluetooth working correctly
Power off and on - disassembled and re-assembled to restart basic install process multiple times - no luck
Factory Reset (found 2 methods) just using paper clip on back had success restting
Base station recovered - led lights are green
Still can't discovere base station
What now?
Netgear recommend you do the setup with a smartphone for the smoothest experience. Not sure why your computer wouldn't work but try your smartphone first
I am having this exact same problem. Did you find a solution?
Tell us in detail what you've done and the various results. Include all info such as LEDs lit and colors.
