If you can get to the settings of the base unit, you can attempt to restart the base...
If not, there's not much you can do remotely... the base you can maybe access remotely, the cameras not.
Remote usage, has additional issues that normal installs don't see at times ( don't know your setup ) such as vacation homes , etc.
In remote locations I try to recommend that users hook the base units ( and modems ) into a UPS to eleiminate many power issues.
Sometimes if there is a power outage, and it stays down for a while , I've seen the base loose sync to camera. This doesn't happen if the base stays powered ( even with internet down ) If the modem is in the max to the UPS, the system will stay functional unless there is an internet feed line down
That stated, any system will go down if the feed source is out
As to regular outages, Not so much here as mine is on a UPS and I can said it hasn't gone down in 1 1/2 yrs.
The only other option I can think out ( outside the box type thinking ) is some sort of device that can turn on / off an ac outlet remotely.. if the base is cycled thru power off/on it will usu come back online automaticly
Good luck
Love it...glad to hear its working.... I use to at one time use a timer that would turn off for 1 min every 24 hrs for a remote location due to problems.
After looking at it, I like the Wemo so much ( wifi only, no hub ), I just ordered 3 to test .
The problem may be yours. Give us as many details as possible. What have you tried? What LEDs are lit and what colors?
