Servers down this AM ?
OK... d/l is 25Mb, up 7 Mb.
Arlo base all normal... matter of fact can get subscription info in under settings, but no live/static cam views
Three differnt browsers, all same ( tho I usu use Firefox )
All six cameras saying "GETTING STATUS..."
Let run 30 seconds and reset each browser, No change.
Let run longer and the dreaded " Your base station is not connected to the Internet. Please make sure it's powered on and connected to your router."
All cams offline as per settings page.
Not good Netgear.
Ok... not too bad.... All is up again.
servers? All came back in 15 mins.
yes same issue here
all wifi and network normal, no changes, can only surmise problem with Arlo Server, will keep trying ...... half an hour so far
does the internet icon on the hub appear amber for you guys too?
Same here, just purchased and have had issues through registration and now getting camera status.
Hmm... up again in about 45 minutes, possibly something to do with a quota allowance?
Over the weekend we experienced an outage that may have affected a small number of users. This was resolved a short time after the outage was discovered and we are investigating the root cause. Please let us know if you are still experiencing any issues.
