  • 2 Replies
  • 3733 Views
Bullrog
Hello:
I have reviewed similar questions on this forum but am still confused.  I would like to have the capacity to arm only 3 of my 5 cameras to be labeled as "At Home" (these are the outdoor cameras).  I do NOT want a schedule created because my "At Home" schedule varies varies widely day to day and sometimes hour to hour.  Would someone help me please to accomplish this goal, if it is possible?  I'd be most appreciative.
First,  homework, read this ;
https://community.netgear.com/t5/Arlo-Knowledge-Base/How-do-I-create-a-mode-for-my-Arlo-Wire-Free-ca...
Second Tips;
Any camera NOT in the active Mode is OFF
Only ONE Mode can run at a time
So you must create a new MODE...call it OUTSIDE
Go to MODE page, at bottom is ADD a new mode , click
follow the directions and PUT in the first of your 3 outside cameras, pick what you want it to do and then SAVE
Now you should have a nes Mode called OUTSIDE with the first of 3 cams included.
Now go back and EDIT that mode ... add the next camera, repeat with the last camera
Now you have default ARMED (all on), DISARMED ( all off ) and OUTSIDE ( 3 outside cams )
When you want only them armed , just pick the mode OUTSIDE
Second Tips;
Bullrog
Thank you very much for the very clear instructions! Following your guidance made it very easy.
