One of my 3 cameras has started showing a red tint. They are only 2 months old. I have installed 4 new batteries, that did not help. Rebooted the base station did not help. Resynced the camera did not help. Does anyone know how to fix this? Thanks for any help.
Thanks for the reply. What if the cameras are more than 12 months old, will they just keep replacing them?
Well my 2nd camera has got the red tint now, this one was bought from Amazon so obvioulsy buying from an "approved" seller makes no difference!! 😕
Turning the camera upside down and tapping/banging it does help but is only a temporary fix, it's obvioulsy a manufacturing fault with the IR sensor or a bad batch, we've have these cameras at work for a year now and never had a problem with those. Netgear should issue a statment and offer new cameras to everyone who is having problems wherever they have been purchased from!
Replacement cameras that I got for the same thing do not work either, They go frim black and white to color then go off line and you can not get them back on line even changing batteries that were new to begin with, bumping cameras etc, etc, etc. They certainly know they have a problem or they are trying to avoid the problem. For the price of each camera they should be top quality!!!
How didi you fix the red tint
I am also having the same red tint issue as well. Seems like this requires a software fix or something as it is becoming more prevalent.
Does anyone know a fix for this or does netgear replace these camera that are intermittent with this problem?
Reading the rest of this (and other) thread would provide the answer. It's worthwhile reading a few pages of any thread to check it out before posting yet another "how do I fix this" when the answer is well-documented.
Open a case at https://www.arlo.com/en-us/support/contact.aspx
Simply repeating the problem without acknowledging the answer does nothing. Of all the posts I've written, easily 50% (75%?) are repeats of the same answers. It gets tiresome, hence some attitude.
I'd much prefer it if you, and anyone else, would help out with solutions as they're discovered, whether new to the community or the person.
I made a comment on Arlo Smart Home's Facebook site about their red/pink pictures. Guess what....Arlo blocked me!
Everyone needs to go to their Facebook page (Arlo Smart Home) and let them know that they need to be accountable for selling and continuing to sell defective cameras.
This is has been going on for over a year!
Business is wiping their hands of it. They referred me to the warranty.
Do you stock in this company? Let me say this again slower for you. I refuse to pay $30.00 shipping to replace one of the many cameras that are defective!
I can't believe Arlo has no issue continuing the sale of these defective cameras!!!
I have the same issue with my outside camera. Since it's about 10 degrees F out there, I'm going to wait a few days until it warms.
I reset my whole system and synced my indoor camera and that fixed that. When I get my outdoor camera in I'll sync it. If that doesn't work I guess the solution is to contact support. More than likely a return for another device solution and no other solution offered.
~Paul
I have tried all solutions offered and had no luck. I had a great picture for two days and then the infamous pink display. It's a defect that Netgear Arlo is refusing to acknowledge. When I brought it up on their Facebook page, they blocked me. What does that tell you....
