Re: Arlo Stuck In Getting Status
Still stuck in "Getting Status" on my surfpads. Restarting, reinstalling does not work! Only way to get the status indication is to use an Android phone with version 8.0 or higher (surfpads has Android 6).
And since the last firmware "update" the picture resolution has decreased and status changes over the phone when connected to a mobile network dose NOT function!
Any company selling "Security products" and that has an active customer forum and choose to NOT monitor or respond to their customers problems is grossly mismanaged an an example of utter corporate stupidity.
There is NO response from Arlo after ticket has created for a week.
Follow up on your own. Don't let the ticket close - pester them.
Still the same problem. Almost all the time no status on phones or surpads, frequent drop out of base staion connections.
When, or if !!!, a movement is detected it takes ages before the recording can be seen. And recordings from all of my four cameras has a very low resolution since the last "update".
No help from Arlo suppport!
It seems to me that Arlo has stopped giving support to older versions of cameras, instead only concentration in pouring out new models.
Presently rewieving other manufacturers solutions as Arlo is NOT a security system anymore!
Looks like you are using the Arlo Pro system so I can't say that your out of luck because your using the Arlo basic/legacy system but based on the numerous threads and complaints about the "getting status" and in my case occasional "Base station is offline" messages, there's something SERIOUSLY up on the company end and no one seems to be alerting their customers or indicating that a fix is in progress.
I purchased another system a few days ago (Amazon Cloud Cam) and despite not having all the features of the Arlo system, I'm very happy so far with the performance. Resolution in particular seems much better than what I had with my basic Arlo system.
Still having the getting status issue. If this doesn't get fixed soon I'm thinking I need to start looking for alternative camera solutions. I'm open to suggestions of reliable security camera solutions if anyone has some.
it gets better after upgrade app to new version 2.7.11_25630.
it used to be version 2.7.10_25620
Abandon the system and move onto something more reliable. Netgear clearly isn't doing anything to correct these issues and leaving their customers to struggle with a defective product platform. There are better systems out there but compare features as no two are completely the same. I switched to Amazon Cloud Cam and have been very pleased with the performance and reliability.
It's atrocious customer service. When Arlo sees so many people having the same problem then it isn't a random issue caused by a particular phone or phone operating system and should not require turning on and off the base, your phone, or anything else. Some of these chats are marked "solved" though if all of these people keep haing this same issue - it isnt solved.
My camera worked fine until it updated firmware - now constant "getting status" message with the occasional "you are not connected to the internet." This is an Arlo issue - post solutions on the home page. This is awful customer service.
We have the right to a system that actually works and doesn't leave us UNprotected. ARLO has really shown how much they care about their customers (not a bit).
My advice is to return the cameras and use your money to buy a professional security system. I have given up on Arlo, in my opinion the company has since long abandoned their original products and are only working on pouring out new models.
Extremely bad customer service, extremely long response times to serious problems (if ever). I feel that they are regarding Arlo as a toy (all be it a costly one), definitely not regarding it as a security system. Which today it´s NOT
As already recommended, return your system and move to something with reliable service and support from the manufacturer. I was without reliable service and stuck in the "getting status" dilemma for a month. Tried every fix recommended by Arlo and users on this forum... no dice. Switched to another camera system and have had no issues since and much more responsive customer support.
same problem with app on line works but app is useless at getting information stuck in getting staus reinsting app makes no difference rebooting base station useless just put in new batteries as well
The same problem occurs again after the firmware upgrade.
There is no problem on Web portal
I seems like many people have same problem intermittently.
Donot know why Arlo can not resolve this problem permanently or will lose many customers.
Base firmware version: 1.14.0.2_2776
Camera firmware version: 1..92.0.23_32920
one more thing I found out that the phone app can not reconnect the network after it wakes up from sleep mode.
It shows this error message when open the app:
"You are not connected to the internet. Please check your connection"
However, the network is working for every other apps.
Tried. But, got error message:
There was an error processing your request.
Did you try and use the link I provided above?
Of COURSE we've tried customer service. Can't you see the many, MANY complaints saying customer service isn't helping?!
