Still stuck in "Getting Status" on my surfpads. Restarting, reinstalling does not work! Only way to get the status indication is to use an Android phone with version 8.0 or higher (surfpads has Android 6).
And since the last firmware "update" the picture resolution has decreased and status changes over the phone when connected to a mobile network dose NOT function!
Any company selling "Security products" and that has an active customer forum and choose to NOT monitor or respond to their customers problems is grossly mismanaged an an example of utter corporate stupidity.
Same problem here!
on Android phone (app version 2.7.10_25620)
reboot phone works one time and does not work and get same message again after login 2nd time.
reboot base station works one time and does not work one hour later.
Can Arlo support fixes the problem and provide long term solution?
I did follow all suggestions in this community.
I tried to uninstall and reinstall the app on the phone as well.
It works only for first time.
one hour later, it does not work anymore. Have to shutdown or restart the phone again to work one more time.
btw,
the camera firmware version: 1.092.0.23_32920
Same problem. I tried everything suggested herein. No luck.
most frustrating... this is the security of my home...
we we need urgent solutions!
It was working satisfactorily before the recent update.
Arlo support has openned a ticket.
Waiting the response...
Hello..., customer service, Bueller, ....hello???
Time to move on to another camera provider. Jumping on CNet to get some recommendations. Arlo/Netgear is apparently throwing in the towel on what was a great product with awesome potential...
@Catfarts What are the status LED lights displaying on your base station?
Not here.
I have the "getting status error" issue as well as many other random issues since the memorial weekend. Apparently there was a firmware upgrade that effected some base stations. I called and described all the various issues I have been having randomly. After discussing it for about a half hour the agent started a support ticket. We had a mutual agreement to not troubleshoot as there was no point. That was May 31st 2019. Hoping to hear back from a support engineer soon as my camera system is no longer dependable. Everything was working fine till 2 weeks ago. VMB4000R3 5 arlo pro2 camera's as well as the doorbell. All purchased within the last 6 months.
YES! I'm having the same exact issue. My system has been working flawlessly for over a year and now it's awful!! ZERO reliabilty from the system for the last couple of weeks. Randomly goes offline and randomly will get stucks on "getting status". ARLO????????????????
Same issue for me as well. Getting status almost every time I go to check my cameras. Very aggravating.
Hello,
What device & OS are you experiencing this issue with?
For me, I use the app on an LG Harmony 2 which is running Android 8.1.0
Perhaps the Arlo/Netgear moderators and higher ups could post something on the home page about what is causing these problems, apparently across all Arlo systems and connection platforms instead of randomly asking worthless questions on the community boards. Seriously, everyone on these threads seems to be having the same problems and all started about the same time so... something with a firmware update went sideways or something but you can rest assured, the longer it takes for someone to step up and share what the problem is with all of your customers, the more likely THIS customer will vote with their wallet and find another camera system.
For others wanting to know what else is out there, I've been researching through CNet and other sources and it sounds like the Amazon Cloud Cam is checking most (not all) of the boxes for reliability and value. I'm not wasting too much more time with Arlo if they are content to sit on their hands and not offer any real solution or explanations for the ongoing issues...
Galaxy 8+ android 8.0.0
