Hi. Does anyone know why this happens? My cameras only recently went bonkers. About half of all library records play with the image partially or completely covered with green screen, and appearing as smeared thumbnails. The problem affects both of my cameras pointed towards my entryway so I’m inclined to think it’s a network/software problem. Solutions welcome 🙂
Camera doing the same thing for a few weeks now on and off.. not seeing any solutions.
Each and every one of them has the same intermittent pixelation, then green screen then loads of lines, at various different times. Hugely frustrating.
Has any of the tech heads come up with a solution yet? My system is a couple of years old, granted. However up until 2 weeks ago it never ever had an issue. Help!
Thank you for the attachments, the development team is investigating these reports/attachments. I will provide an update as soon as possible.
I have posted a picture earlier in the thread
Arlo needs to find a solution fast otherwise there will plenty of people changing camera providers.
I have been waiting for a fix on their Activity Zones for MONTHS now. Nothing!!!
I’m done. Maybe I’m stuck with the hardware but I sure as heck am not giving them another dime for ANY SOFTWARE RELATED!!!
Tomorrow I will cancel my subscription to the “Smart “ plan.
It is totally useless as nothing works anymore. I still have an open ticket for the Activity Zone issue but no one is updating me. This is customer service??????????
And its gone back to sending alerts for things I have selected NOT to send, as well as the so called “smart” features. And now the vertical lines and green screen.!?!?
One more year on Best Buys Geek Squad coverage and if nothing improves I will send it ALL BACK and buy a new washing machine.
I am really, REALLY, so done with this inferior product. And I will be sure to put the word out.
Really, I’m done!
One of them is a brand new camera too to try to eliminate it from the equation. Pressure now on you Arlo.
Sent my email to askarlo@arlo.com as requested but no response
Thank you, yes we received your email & I will be provide an update as soon as possible.
I also have this issue. Is it an Arlo issue or is my one camera faulty?
Any advice for me?
@ArnieLittle wrote:
I’m also having the same problem with my new Arlo video doorbell (activated in mid June 2020). Videos recorded are useless as they display with either a green screen, blurred lines or pixilated footage around images of people.
I’ve done all the usual to troubleshoot:
- Checked that firmware is up to date.
- Reset device, multiple times.
- Checked wifi connection (there is no issue with connection to Arlo Ultra base station which is located within acceptable proximity to doorbell).
- Reduced video resolution and motion sensitivity.
- Logged a job with Arlo support.
NOTHING HAS WORKED. I find it extraordinary that multiple customers have raised similar issues over an extended period of time, and there does not appear to be a viable solution yet. Disappointed Arlo. When will you provide a fix?
Never gonna happen. This is the new normal. Arlo doesn't give a DA.N about the quality. The new leaders don't want to stick another penny into bandwidth and servers. Get used to it.
I was contacted by support directly, and they asked for screenshots, I gave them four from two cameras along with model, serial numbers and software revs. They came back with the same stuff reset, pair, check the bandwidth and the like. Stuff I had already done. I have asked for a software revision history to try to help them sort it out.
Thank you for the attachments, this info has been escalated & I will be providing an update here as soon as possible.
My ARLO PRO camera image is tinted green at times. It’s only 1 of the 5 cameras and it just started after several years of service.
Do you want video recordings too?
Seems like the issue has been fixed from my end.
Had the customer service team email me saying that the firmware has been updated and to make sure my app is up to date.
No more issues since then!
