No geofencing notifications?
  • 9 Replies
  • 2672 Views
speedf1
So I don't know what's happened.  I moved from a OnePlus 6 to a OnePlus 8, and now get no notifications when the geofencing is set home or away.  Looks like the notification settings in the app are set correctly.  Anybody got any ideas?
9 REPLIES 9
Arlo415
Ever since I moved from Note 8 to Note 20 geofencing does not work and extensive support from Arlo did not fix the issue.
ShayneS
Hi @speedf1
  Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
ShayneS
@Arlo415
May I ask for your case number regarding the Geofencing issue? What were the last steps/resolution support provided you?
Arlo415
Arlo415
45 minutes of support with no resolution. Even cleared data uninstalled and reinstalled. We did EVERYTHING.
ShayneS
@Arlo415
I am looking at the notes within your case, are you having an issue with the mode not arming and disarming when you're in & out of the zone?
Arlo415
Yes
ShayneS
@Arlo415
Are you using a schedule with geofencing by chance?
Arlo415
No schedule.
