So I don't know what's happened. I moved from a OnePlus 6 to a OnePlus 8, and now get no notifications when the geofencing is set home or away. Looks like the notification settings in the app are set correctly. Anybody got any ideas?
Hi @speedf1
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
May I ask for your case number regarding the Geofencing issue? What were the last steps/resolution support provided you?
41980945
45 minutes of support with no resolution. Even cleared data uninstalled and reinstalled. We did EVERYTHING.
I am looking at the notes within your case, are you having an issue with the mode not arming and disarming when you're in & out of the zone?
Yes
No schedule.
