Loaded batteries in wrong slot for Arlo Wire-Free camera. Blinked blue once and quit and won't work.
  • 7 Replies
  • 2152 Views
jadssr40
Messed up loaded batteries in wrong slot, blinked blue once and quit..opened it back up corrected slots, now camera will not work...fried?
jadssr40
Thanks everybody that answered...I had left it alone, loaded the batteries one more time and it started working....Thanks again!!
7 REPLIES 7
Unlikely - reverse polarity shouldn't cause a problem. Make sure you only lightly place the batteries in their slots and let the battery door do the pushing.
ant
Mentor
Mentor
Try another camera with those batteries?
jadssr40
Deleted from my system, now trying to add it back in, won’t sync..keeps blinking blue than after a long period blinks yellow
jadssr40
impossible my camera will not sync....tried everything, possibly hurt it when I reversed batteries and closed it...it actually blinked once when I closed with batteries in wrong slot...now when I install batteries, the blue light on right side stays on..when I try to sync it flashes but won't sync...thanks for trying to help..I think it's done..
jadssr40
Is there somewhere that repairs Arlo cameras?
Arlo. Use the Contact Support link at the bottom here for a hardware problem. I don't know of any reason reversed batteries would cause harm - a simple diode inline with the batteries would prevent damage.
jadssr40
