Hello.
I just noticed iOS app showing a camera's low battery, but I never got an e-mail notification about it. Did anyone get any low battery e-mail notification recently? I used to get them until this incident.
Thank you in advance. 🙂
As noted many times before, this is an ongoing issue - it's supposed to work but isn't for some reason. Checking the battery icon is the only reliable indication now (unless you want to consider an offline camera due to battery a reliable indication).
jguerdat wrote:As noted many times before, this is an ongoing issue - it's supposed to work but isn't for some reason. Checking the battery icon is the only reliable indication now (unless you want to consider an offline camera due to battery a reliable indication).
Thanks. How annoying, and I am surprised Netgear still hasn't fixed it if it is that old. 😞
We are investigating an issue with the low battery e-mail notifications being sent. We hope to have a resolution soon and will keep you posted on any updates.
Thank you,
JamesC wrote:We are investigating an issue with the low battery e-mail notifications being sent. We hope to have a resolution soon and will keep you posted on any updates.
Thank you,
Thanks. I hope it is really soon since this is annoying.
What about the preferences not being listed under settings? How do I view what happens with old recordings? That button is shown to be listed under preferences.
denjen wrote:What about the preferences not being listed under settings? How do I view what happens with old recordings? That button is shown to be listed under preferences.
Hello. Please post a new thread of your off-topic issue.
denjen,
There is no longer a preferences listed under Settings as those features were moved or became enabled by default.
Old recordings will be deleted on a schedule based on your subscription. For example if you are on the Basic Subscription, all content will remain on the cloud until it has reached 7 days old. Once it is 7 days old it will be automatically erased by the cloud.
