Arlo ports?
Hello,
Im new to the Arlo and im quite satisfied with it. Im assuming poor battery life for this first go around because of how often i check in on my cameras. Recently i have been noticing that all of my camera's are offline(2 cameras) and in order to get it back i have to reset the hub via the app. i am running the most recent firmware for the base and the cameras...but still disconnecting every 30 minutes to 1 hour.
It looks like this is an area for improvement after the most recent firmware upgrade and im sure Netgear is working on it(fingers crossed) but is there a port that i can assign to Arlo in order for it to have a dedicated reliable IP address. Im wondering about static IP even.
Thanks,
tyler
The address for the base station would be assigned by your router's DHCP server. I use static IP addresses via the DHCP server (basically just assign a static address to the MAC address) for a few devices. I haven't had a problem with not assigning an address to the base but it's certainly doable and easy enough.
I used the normal dynamic ip adress during setup... can say I don't think Arlo base has dropped out since I started it up back in October.
( only when i screwwed things up a few times ).
Is it possible you have a glichly router?
