My Arlo Is Not Recording To My Library
As of 4:00 p.m. on 8 July 2018, my system stopped recording detected motion. I've rebooted/restarted the base station. I confirmed through the home screen that the base station and all cameras are armed. I'm able to see live views through the cameras but can't see any recorded activity. The system worked fine until 4:00 p.m. on the 8th. I didn't change anything with my home internet system, etc., then, so I can't think of why it stopped working. Apologies for what seems like a duplicative post but the system wouldn't let me add to an existing thread from two years ago. Thank you.
I still haven't found a resolution to my problem. I'm really frustrated because I've purchased a system that only worked for ONE DAY and nobody seems to know what the issue is!!! It just defeats the purpose of having a security camera system!!!
You didn't report back after your previous post. I'll guess it didn't go well.
AT this point, you seem to have two options:
1) Remove everything from Settings, My Devices and start fresh. Claim the base first and then sync the cameras. These things are computers and sometimes computers get goofy.
2) Use your existing case or open a new one with support here:
Part of me does not want to post this because I feel like things might go south if I say something. At Thankgiving I was having issues close to this. I was about the toss the system in the trash. I did a full system wipe. Did a complete hard reset of the base, unstalled the app, all cameras had fresh batteries, and just redid it all. It was like unboxing it from new. So far over these last 6+ weeks things have been working great. It has been working fully to how I have been wanting this system to work from day one. I even bought the one year subscription for 8 month price special the other week. I just wish I knew what the cause was. I did not want to post this till I had this system acting 100% right for at least a month.
Any advice would be appreciated.
What firmware version is the camera running? Is the base station up to date with the latest version? I have attached a link to our latest updates - Firmware
Use a browser, not the app, to check and set your modes, rules and schedule. I've had a few things changed on me that I had to fix.
Only solution I have found is to trash the Arlo. I'll sell it and buy something else.
Since you apparently have two cameras recording the same location, it may be that the Pro camera has a bad angle for motion to be across the FOV. It could also be the sensitivity setting needs to be tweaked on the Pro - I doubt the settings are exactly the same between models or even necessarily between the same model cameras.
Same problem here for five weeks now. Managed to get them working again, but for around 48 hours, after a complete reset (including taking the cameras down to link them back to the base unit). Last support request ignored so far.
I’m coming to the slow conclusion that Arlo doesn’t work and they don’t care. If so, this was a complete waste of £1000+ and £120 pa to subscribe to recordings that don’t record.
