My Arlo Is Not Recording To My Library
As of 4:00 p.m. on 8 July 2018, my system stopped recording detected motion. I've rebooted/restarted the base station. I confirmed through the home screen that the base station and all cameras are armed. I'm able to see live views through the cameras but can't see any recorded activity. The system worked fine until 4:00 p.m. on the 8th. I didn't change anything with my home internet system, etc., then, so I can't think of why it stopped working. Apologies for what seems like a duplicative post but the system wouldn't let me add to an existing thread from two years ago. Thank you.
CatLadyDNA,
Have you made sure your base station & devices firmware are up to date? Have you tried to reboot your base station?
Hi,
Yes, i called Arlo support and did everything they asq.
Check the Arlo report (emailed to me):
--asked cx to reset the base station
-guided through steps to reset the base station
-base station was successfully added
-guided through steps to add camera
-camera were successfully added
-still camera was not recording videos
-asked cx to keep all camera near the base station for overnight
-case no. was provided
-eoc
Thank you for choosing Arlo.
Team Arlo
KG56,
Have you tried to reboot your base station & test again?
This is a systemic issue and needs to be addressed. The only way I can fix this issue, which recurrs consistently is by removing my devices, re-syncing to base station, and re-setting up all my custom settings.
The camera still records, I know it does because I'm on of the few idiots that pays for Arlo Smart Premier + CVR. I can see the alerts as green bars in my CVR. I know the camera is not malfunctioning else those green bars (indicating activity) would not exists in the CVR. I can also see the man turn from black to yellow when recording is supposed to occur.
There is a code issue with the Library that makes the library stop accepting new recordings at a random interval, even though the cameras are acting properly. So the issue is probably base station code related. The only thing that resets this for me is removing cameras and re-adding them as new.
Ignoring this issue wont make it go away.
Please, ShaneS, escalate this issue. It's happening to a lot of people. It's not just me. This needs to be de-bugged on Arlo's end. I LOVE these cameras and I am pretty upset. I don't want my money back or to complain as an angry customer. I want this product to function. I use these cameras to monitor my beloved pets, including my diabetic cat who is in remission. I need to see when he eats in order to monitor his health. I also have to work full time. This is so important to me. Please, I am begging you to try to get this looked at in a real way.
Thanks, I'll try that when I get back home. It's just frustrating...ugghhh!!!
What's the exact issue? Have you verified that the current mode selected allows recording (it's not the Disarmed mode) and the motion indicator(s) in the Devices tab are black and not gray? Can you live view? More details are better.
It's "armed" but the motion indicators are gray. I can do live viewing but it's not detecting anything. If I walk outside, move my car or anyone pulls up, it doesn't record but if I wave my hand really close directly in front of the camera it will record so I'm confused. Please help!!!
I would toggle the mode to Disarmed and back to Armed (or your custom mode) as well as rebooting the base and opening and closing the camera battery door. Might be worth checking the battery level, too.
While you're checking your mode, verify that the motion sensitivity hasn't somehow gotten reduced to nothing.
I have five cameras attached to my system....four of them are detecting and recording fine. One camera is sending me push notifications and I can live view, but no recordings appear in the library after notification. Any suggestions?
I see some others are having the same issues. This system is only 2 months old.
About all you can try is to reboot the base. Does this happen on both the app and the web browser?
@jguerdat Same . ive reset everything and nothing. might as well take them down
Open a case with support here for a possible replacement:
Thank you , I sure will because I still haven't been able to get my system to work after trying everything that you all advised me to try. Thanks again.
Thanks, I'll try that when I get home. Thank you again.
