I will be mounting this in a carport at the beach. What installation options are there so the unit is secure and won't get stolen. The magnetic mount and plugable system doesn't look secure for outside.
There have been a few posts about this....
Netgear says add-ons ( mounts, etc ) are in the works.
But any camera mount with a standard screw mount will function with Arlo. There are amny models out that are tamper resistant.
OceanLC wrote:I will be mounting this in a carport at the beach. What installation options are there so the unit is secure and won't get stolen. The magnetic mount and plugable system doesn't look secure for outside.
I am not sure there is a good way to ensure the camera can't be stolen as whatever you use will probably utilize screws and the camera tripod thread. All you can probably do is make it a little more difficult that having it pulled off of the magnetic mount. I am using this mount and you could also utilize tamper resistant screws, but again they could still unscrew it from the tripod mount.
Greg
This may be of interest to those needing additional mounting options. I just purchased 5 of this Panavise 845-246W Deluxe Micro Mount (Cream) at Amazon and installed 2 of them today and very happy with the quality and ability to make adajustments. Check them out.
What about third parties from local stores like Fry's Electronics, Best Buy, Costco, Walmart, Target, Office Depot, Staples, Office Max, Radio Shack, etc.? Thank you in advance.
ant wrote:What about third parties from local stores .......
Any camera mount with the standard screw thread mount will function
Thanks. Any good known ones from local retail stores?
So the screwmount is not secure as someone can simply unscrew the camera. So in my opinion, the solution is to get a screw mount and use locktite red:
Loctite® Threadlocker Red 271™ is designed for the permanent locking and sealing of threaded fasteners. The product cures when confined in the absence of air between close fitting metal surfaces. It protects threads from rust and corrosion and prevents loosening from shock and vibration. It is only removable once cured by heating up parts to 500°F (260°C).
You would have to be careful how you mount it so that you could access the battery compartment and still be able to change the batteries.
http://www.loctiteproducts.com/p/t_lkr_red/overview/Loctite-Threadlocker-Red-271.htm
Please see my post below (or above) about usinge locktite red - had the same concerns....
I've tried 3 different screw mounts and 2 made it so the camera had to be removed to open the battery door....
Also, anything can be stolen and the locktight won't matter if they rip the bracket out.
So, I really don't RED locktight is a good idea. But If you think its good for you then by all means go for it.
I still think the best solution is to place it where its not easily accessable ...
That is a really good point - the bracket and the arlo arrive tomorrow - will see - also there is an issue with plastic and red locktite - they are not compatible - so the attatchment point on the arlo has to be metal .....will see tomorrow.....
....with plastic and red locktite - they are not compatible - so the attatchment point on the arlo has to be metal .....will see tomorrow.....
I believe the threaded insert for the camera is metal... but remember since it's a insert it can prob snap off too.
Yes, the magnetic mount is a (security) joke, a stand-alone threaded mount (which I use) only means someone needs to unscrew the camera, and Lock-Tite can be defeated with a modicum of effort. But really, when does it stop? Will we be putting bars on our windows next or walking down the street with helmets? At some point we have to advance a little inherent trust and can only make things as safe as fate allows. Beyond that, if somebody wants to do the unthinkable, not much is going to stop him or her. Until we accept this we'll just be subjecting ourselves to unrelenting worry and premature gray hair.
Locktite doesn't appear to be a viable solution due to the limited battery compartment access needed. I think the idea here was to try to find a viable solution to deture theft of the camera - like locking ones car - but that may have flown over your premature grey head.
R_Lowe wrote:Yes, the magnetic mount is a (security) joke, a stand-alone threaded mount (which I use) only means someone needs to unscrew the camera, and Lock-Tite can be defeated with a modicum of effort. But really, when does it stop? Will we be putting bars on our windows next or walking down the street with helmets? At some point we have to advance a little inherent trust and can only make things as safe as fate allows. Beyond that, if somebody wants to do the unthinkable, not much is going to stop him or her. Until we accept this we'll just be subjecting ourselves to unrelenting worry and premature gray hair.
So it arrived - I realized that the battery compartment would be unaccessable with the mount I bought. Locktite turns out not to be an answer........at least for me
jayats wrote:Locktite doesn't appear to be a viable solution due to the limited battery compartment access needed. I think the idea here was to try to find a viable solution to deture theft of the camera - like locking ones car - but that may have flown over your premature grey head.
I wasn't advocating the use of Lock-Tite, and was commenting solely on the futility of worrying needlessly (it's a forum and you can expect folks to comment along those lines). So MY head (or hair) isn't gray because of it. You seem to have missed my point entirely; but if I have to explain it further, I'm sure you wouldn't understand.
I have had some good luck using a Kensington slot adapter and a standard cable lock. I can post more pictures and info if anyone is interested.
Your image did not appear 😞
jeff_757 wrote:I have had some good luck using a Kensington slot adapter and a standard cable lock. I can post more pictures and info if anyone is interested.
Odd.. I see the picture in my post and in your reply. Is anyone else having a problem viewing the picture?
jeff_757 wrote:Odd.. I see the picture in my post and in your reply. Is anyone else having a problem viewing the picture?
https://community.netgear.com/t5/image/serverpage/image-id/362iF17BF0A96D303E35/image-size/medium?v=... doesn't show for me either. I wonder if it is only showing for the owner?
Should I be choosing 'Public Album' or 'Private Album' when inserting a picture? I have added it to this post as a smaller image to see if that makes any difference.
The pictures seem to load in IE but not Firefox or Chrome
jeff_757 wrote:The pictures seem to load in IE but not Firefox or Chrome
Same problem in my very old, Windows XP Pro SP3's IE8. 😞
Public of course! Private to you only!
Attempting image upload using Chrome.
						Accessories4
						Activity Zones1
						Amazon Alexa1
						Apple HomeKit2
						Apple TV App9
						Applications mobile et en ligne1
						Apps4
						Arlo Go3
						Arlo Mobile App722
						Arlo Pro36
						Arlo Pro 21
						Arlo Q (Plus)3
						Arlo Smart196
						Arlo Web and Mobile Apps18
						Arlo Wire-Free30
						base station1
						Batteries529
						Before You Buy924
						Can't view cameras live at all1
						Dépannage1
						Détection de mouvements1
						Features1,064
						Fehlerbehebung1
						Firmware Release Notes93
						Google Assistant1
						Hardware1
						home security1
						IFTTT (If This Then That)105
						Installation2,046
						Iphone 14 pro1
						Live view1
						Modes and Rules1
						Motion Detection2
						Object Recognition3
						Online and Mobile Apps983
						Online und mobile Apps1
						Order Not Going Through... help please!1
						Other Discussions1
						Partner Integrations4
						Security1
						Service and Storage14
						Smart Subscription3
						SmartThings71
						Troubleshooting9,083
						Videos233
						Vidéo2
						Warranty & Contracts2
