Hope someone can advise me?
I have four cameras but at certain times I want only one, the outside one, set for motion detection can someone explain if and how I can set this up?
Thank you guys and girls.
No , I prob just clicked on the wrong one... here you go.
As mentioned, you need a custom mode called say ; outside, for just the outside camera ... the default you have are Armed ( all on ) and Disarmed ( off)
Other tips that may help;
With MODES, any camera NOT in the active mode is OFF
Only ONE mode can run at a time
When using schedule, Modes do not go thru midnight so split time into two parts , up to 1159pm and start agin at 1200midnight on next day
you need to create a Custom mode ( to split the cameras up as needed )
Thank you for your reply and link to my question.
What I want is to be able to do is to activate the motion detector on only one of the four cameras when needed, unless I have not followed the info correctly the link advises on setting each camera for alerts etc. and not for solo activation.
Please correct me if I am wrong.
Thank you.
Thank you for your help, much appreciated.
