- 2
I was wondering if anyone knew how the live streaming works. It appears that it goes through Netgear servers and then to the phone/computer.
I can be at home, logged into the same wireless network as the base station (and cameras obviously), and try to stream video. Sometimes it fails. Sometimes it works. I click on the play button to start viewing. It gives me the rotating circle with "Please Wait." After about 30 seconds, if it fails, the circle disappears and the play button pops back on the image. I can try this several times and eventually I might get a live streaming video.
If it does go through the Netgear servers first, 1) they are using a lot of bandwidth on their end for all the users that watch their cameras and 2) they are using up a lot of bandwidth on my end as well (video has to go out and then back in). If it does not go through their servers first, why is watching live video a hit or miss type of action?
I can only speak of my experience but when I have issues like that I log out and back in which clears my display issue. That may well not work for anyone else but I give it several seconds to work give up and start the refreshed login. Doesn't help you now but try it when this happens again. Also, try the app or browser, whichever you're not using.
I just installed an Arlo Pro and the live streaming and audio are useless. There is perhaps a 30-60 s lag in the video and the audio breaks up on one direction or the other. Is this due ti the relatively low bandwidth of my DSL (about 3 Mbs)?
Cameras
Firmware: 1.2.10342
Harware Ver.: H7
Base Station
Firmware: 1.8.1.1_10234
Hardware: VMB3010r2
Internet: 250Mbps down\50Mbps up... usullay tests at around 180\40 even at peak times.
Router: Asus RT-AC87U with 3.0.0.4.380.4180 Firmware.
I'm on my second base station... First one died at about 6 months... RMA'd it and received this unit.
I experience the same symptoms as the original thread post in 2015. When I click the "Live" button it says "please wait", then the Live button appears again 30-40 seconds later. This is true in IE, Edge, Chrome, the Android App on my Wife's phone and the iOS app on my iPhone.
I get alerts in my email that motion has been dectected, and I can view recordings of these alerts, so the cameras are functioning in some capacity, BUT I can not see them live... This kinda makes them useless... I've been so disappointed... I had to argue and fight with the support team to get them to believe me that the issues I had with my previous unit were not with my network or internet connection.
I hope someone has a solution... If this level of failure and unreliability is the norm with Arlo, then I'm cutting my losses on super expensive batteries and flaky tech and getting Nest cams. Very disappointed.
jguerdat wrote:
Power cycling the base is a good first step. Then, are all your devices up to date firmware-wise? Last, it may be a good time to reset the base by removing all devices in Settings, My Devices and start fresh. I don't have an explanation but it's possible something just got stupid.
Thanks for the reply. Yes, I have power cycled the system (several times), I believe all my devices are up to date firmware wise.
I haven't deleted everything, because the last time I did that, at the Support Teams Request, the base unit wouldn't recognize any of my cameras. That started the argument about it being somenthing in my network causing the issue.
I think this was just a very expensive mistake on my part... I give up.
grogerson,
From your post above, it looks like your system is on up to date firmware. I recommend contacting the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
Just FYI:
I have exactly the same issue. Live viewing simply times out with a return of the [Live] button, never works.
I've thus far not seen one serious technical response from netgear on this. It's a huge mistake also on my end to buy these crappy cloud-cams.
Should have never bought the 3 cams and expensive batteries.
It's not my internet-connectivity (it's among the best and fastest in the world, for consumer-connections), it's not my version of OS or outdated firmware (all up to date). It's not even flash (it works fine for other flash/swf playable sites/videos).
My advice:
Buy Foscam, Uniden or Axis cameras. All of which I have over 2 decades experience with where I have been employed over the years. Those are true security cameras. Never failed on us once. They last for years without one failure, have very well tested and secure interfaces, stable software and reliable motion detection. Only one hurdle: They need power over ethernet or otherwise cabled power.
- 2
