Internet connection
I've just changed my BT Hub5 for a BT Smart hub and now I cannot get internet connection to my base station, can any one help me.
5 REPLIES 5
since it was working before.... check the ports 80,443,123 ( need to be open )
Also access to netgear.com
Sorry, I'm new to this can you explain step by step guide to resolve this issue, thanks Harry123.
I suspect the BT hub is owned by the ISP - is that correct? If so, you'll have to contact them to make the changes.
Also trying to reconnect to the internet and cannot. Pleas advise
Need details. What modem/router, what are the base LEDs showing, what have you tried, etc.? More detail is better.
