arlo live camera view does not stream since adobe flash update
Using PC i can not view live stream using Firefox win 10, i think it might relate to a recent update.
I can still view live on ipad.
Anyone else had this problem and what can i do?
Your issue is more than likely FLASH...
In FF, you now must toggle it on in the new versions. ( look for a little icon in the address bar at right end )
Or you can try Chrome
I'm also having problems viewing live streaming via firefox lately. ONly in last couple weeks has it stopped working. Right around the same time my desktop did windows updates. Of course, I can view streaming on my smartphone though.
Check that FF is up to date and has the latest Flash installed and enabled.
I have latest Firefox and flash installed, it will work with chrome.
it still does not work after disabling protected mode and the other security check box in flash options.
Sometimes the latest update of the browser causes problems that clear up with other updates, whether the browser orthe web site. Right now, it seems that Chrome is the workaround.
Yes, I agree it is Firefox and how it handles flash. I tried looking at going back to the previous version but it's more trouble than it's worth.
Chrome and mobile browser are fine.
thanks for your reply.
Keep checking FF. It may work fine at some point in the future.
