  • 40 Replies
  • 15470 Views
  • 3 Likes
  • 12 In Conversation
Lanns
Hi,
I cannot log into my account from any browser on my iPhone.
Trying to sort out subscription and can’t get in.
Any help would be greatly appreciated
Best answers
  • JamesC
    The development team is investigating reports of this issue.
    Do you get the same error message if you use both the mobile app and the web client at https://my.arlo.com/#/login ?
40 REPLIES 40
@thefamilykg wrote:
When trying to login to "https://my.arlo.com/#/login" I am getting the error "
Http failure response for https://ocapi-app.arlo.com/api/auth: 0 Unknown Error"
iphone w chrome and safari
iPad with chrome and Firefox
Does this also fail on a PC (windows or mac)?
kimmmie123
Try this - it should be `home´ at the end and not `login´ i think
https://my.arlo.com/#/home
https://my.arlo.com/#/home shows "login" and "create account" controls.
When you click on "login", you go to https://my.arlo.com/#/login (which is the page where you enter the credentials).
Navigating directly to https://my.arlo.com/#/login works for me on a PC.
I have seen this particular error reported before by people who were attempting to log in on their mobile browser.  Which is why I asked if it happens using a PC.
thefamilykg
Thanks it issues the same message
thefamilykg
Yes, login works on PC but not iphone or ipad. Thank you! Thats odd, not mac browser compatible or just certain mac systems?
I don't know - I'm not a mac user.
rocketscott
I also cannot login to my account from my android browsers or the Arlo app
rocketscott,
Where are you located? Are you still experiencing the issue? Are you attempting to access while using a VPN?
kimmmie123
Im not using a VPN. Im in the United Kingdom. It only works when I log by shortening the URL to;
Midge1920
I am also experiencing this same problem and http message. Someone help, please!!
DannyBearAgain
I get the error when I use my iPhone browser to access the arlo web login.
The web interface does not play well with Apple devices. That’s why you can’t subscribe using Apple devices.
Try using a windows pc to login or rely on the arlo mobile app.
Midge1920
I actually have an android phone. My galaxy won't let me login to the app or using a web browser. I have also tried using a laptop to login and stil get the same failure response 😕.
Anyways, if I can't use the app on my phone, then this doorbell cam is pointless. Everything was working fine and then I downloaded the update and now I have this problem.
DannyBearAgain
Yes, I seem to see more customers with the new app having issues.
Going forward, never update until you know what bugs to expect.
kimmmie123
What URL appears when MyArlo loads on your browser?
should be https://my.arlo.com/#/login
FWIW, I think that's more about the Apple store.  I think in-app purchases (including a subscription) require the app provider to give Apple a cut.  Though I'm not certain on that.
Midge1920
It's this one :  https://my.arlo.com/account/v4/#/login
Whenever I try the web address that you suggested, I'm automatically taken to the URL that I just posted above.
