The way I had to mount my outside arms, makes the video come in upside down? Is there a way to rotate the video image?
Yes, in settings, camera settings. Select the camera and use the invert image slider.
The invert slider only inverts the image. Don't see the functionality to rotate the image. Have my outdoor one mounted under the roof edge so need to rotate the image on my phone/iPad 180 degrees. A future upgrade please ?
Not at thi s time. Only 180 degree rotation.
Did you try clicking it? It's gray when normal but clicking inverts and turns green to show it's been activated.
Yes. It works through my PC browser, but not my iOS devices. Once I turned it on through my browser, I could then turn it off through iOS. But not the other way around.
soccerbock,
Are you still experiencing this behavior after updating to the latest version of the iOS app (2.2.1)?
Please let us know,
