  • 10 Replies
  • 19148 Views
  • 2 Likes
  • 8 In Conversation
dschiapp
The way I had to mount my outside arms, makes the video come in upside down?  Is there a way to rotate the video image?
10 REPLIES 10
Yes, in settings, camera settings. Select the camera and use the invert image slider.
Joost2015
The invert slider only inverts the image. Don't see the functionality to rotate the image. Have my outdoor one mounted under the roof edge so need to rotate the image on my phone/iPad 180 degrees. A future upgrade please ?
Flexmo
I am having the same problem is there a solution??
Not at thi s time. Only 180 degree rotation.
Flamewinger
Please work on it as many front doors are vertical. Like mine. I have to mount it on its side to get good view of front door area.
Sammy313
My rotate option is not working. The slider in settings is grayed out. What do I do?
Did you try clicking it?  It's gray when normal but clicking inverts and turns green to show it's been activated.
Sammy313
Yes. It works through my PC browser, but not my iOS devices. Once I turned it on through my browser, I could then turn it off through iOS. But not the other way around.
soccerbock
Same problem here. The slide switch on iOS is totally unresponsive.
soccerbock,
Are you still experiencing this behavior after updating to the latest version of the iOS app (2.2.1)?
Please let us know,
