  • 8 Replies
  • 22296 Views
  • 4 Likes
  • 7 In Conversation
snip3rboy
Enable Arlo Push Notification on iPhone/Ipad - iOS 8
On your iOS Device, open the Settings app.
1. Tap Notifications
2. Tap Arlo
3. Make sure Allow Notifications is enabled
8 REPLIES 8
David_NG
Hello snip3rboy,
Thanks for the step by step. I'm sure our Arlo users will find this very helpful.
The Arlo Team
David
Irish2
My iphone sound alerts stopped, and have checked that notifications are on settings.  Please advise.
A quick first step is to uninstall and reinstall the app.  Does it still not notify?
Irish2
Did not remove app, but not logging out seemed to work.
Kravenmorehead
I uninstalled and reinstalled and still not working
KristynM
Hello @Kravenmorehead
Have you verified that the push notifications are enabled for your iOS device via the device settings for notifications? Additionally your e-mail address has to be confirmed in order to start receiving alerts via e-mail or push notification.
To check if your e-mail address has been confirmed you will need to do the following Login to Arlo > Settings > Personal Information. It will say Confirmed if it has been. If it has not been confirmed, you may request to have a confirmation e-mail resent to you.
Looking forward to your response.
Regards,
KristynM
Arlo Support Team
NellCantrelle
2. Tap Arlo
Did it, the setting was right. So why am I not getting push notifications?
Try turning it off, exit to save and then turn it back on.
