Geofencing radius cant be saved. Changed it to medium but next day, goes back to small by itself.
Why radius in geofencing cant be changed? I change it to medium, save it and next day it goes back to small by it self.
Hi Suki4,
What phone device are you using and what iOS/Android OS version are you running? Does it revert back when trying to save through WiFi and/or cellular data?
Regards
Marko
Have you tried reinstalling the Arlo app and rebooting your iPhone 11 to see if that helps?
I would suggest to contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
I'm having this exact problem with my system. There is something wrong with the app/software. Looking for a quick resolution as the incessant notifications are getting annoying (the geography/construction at my location mean the phones don't register inside the small radius but I can't change it).
Same issue. I want to save "small" radius, but it always goes back to large. Very annoying. Please fix it!
